[GRASS-dev] v.in.ogr broken (\w shp)
Helena Mitasova
hmitaso at unity.ncsu.edu
Mon Sep 4 10:03:33 EDT 2006
On Sep 4, 2006, at 6:54 AM, Brad Douglas wrote:
> On Sun, 2006-09-03 at 19:59 +1200, Hamish wrote:
>> Brad Douglas wrote:
>>> Is there an easy fix for this? I'm trying to import a shapefile and
>>> I'm not terribly familiar with this part of the GRASS architecture.
>>> GRASS 6.3.cvs (hamilton):~/hamilton > v.in.ogr dsn=. output=roads
>>> layer=17
>>> Projection of input dataset and current location appear to match.
>>> Proceeding with import...
>>> Layer: 17
>>> DBMI-DBF driver error:
>>> Column 'ADMIN_CLAS' already exists (duplicate name)
>>> Cannot create table.
>>> Error in db_execute_immediate()
>>> ERROR: Cannot create table: create table roads (cat integer, PREFIX
>>> varchar
>>> ( 2 ), NAME varchar ( 30 ), TYPE varchar ( 4 ), SUFFIX
>>> varchar
>>> ( 2
>>> ), FCC varchar ( 3 ), FIPS varchar ( 11 ), ID integer,
>>> FULL_NAME varchar ( 40 ), ADMIN_CLAS varchar ( 40 ), CATEGORY
>>> integer, ST_CNTY_FI varchar ( 11 ), RD_CLASS varchar ( 4 ),
>>> RTE_NUM1
>>> varchar
>>> ( 4 ), RTE_NUM2 varchar ( 4 ), ADMIN_CLAS integer, AREA
>>> double
>>> precision, LEN double precision)
>> DBF limits column names to 10 chars; you end up with "ADMIN_CLAS"
>> twice
>> in the above list. Either change DB column names or user the v.in.ogr
>> cnames= option to rename columns to something unique. (hint, cut &
>> paste
>> above list with modification). Maybe changing DB to SQLite or
>> something
>> helps too?
> Ahh! Thanks!
> However, this does present a usability issue. This is a problem many,
> people will encounter. I was trying to import a standard USGS
> product.
I wanted to ask about it as I had exactly the same problem just few
days ago -
I believe I was importing USGS roads too.
> How about when v.in.ogr encounters this, offer a suggestion to fix,
> rather than simply erroring out? We could almost cut and paste your
> answer above. At least something a little less terse than, "ERROR:
> Cannot create table: [SQL statement]". That describes nothing
> about the
> problem encountered (duplicate columns)[1].
it actually says that, but it does not explain that the duplicate
column is due
to the 10chars limit so I was rather confused too.
so a suggestion for a solution
would be helpful. If DBF does not work directly with a standard USGS
product
it is one more reason to change the default DBMS in future (GRASS7?)
Helena
> What do you think?
> [1] Yes, I do [now] realize that upon close inspection and decent
> knowledge of SQL92, one can readily solve the problem. :-)
> Brad Douglas <rez touchofmadness com> KB8UYR
> Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
