[GRASS-dev] GL + PPM + nviz
Brad Douglas rez at touchofmadness.com
Thu Sep 7 07:18:06 EDT 2006
We had tracked this down and fixed it once already.  It's back:
Creating PBuffer Using GLX 1.3
X Error of failed request:  GLXUnsupportedPrivateRequest
  Major opcode of failed request:  143 (GLX)
  Minor opcode of failed request:  16 (X_GLXVendorPrivate)
  Serial number of failed request:  21
  Current serial number in output stream:  22
This happens specifically when trying to export high resolution PPM from
nviz.
http://grass.itc.it/pipermail/grass5/2006-June/023868.html
Brad Douglas <rez touchofmadness com>                      KB8UYR
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
