[GRASS-dev] GL + PPM + nviz
Glynn Clements
glynn at gclements.plus.com
Thu Sep 7 22:48:32 EDT 2006
Brad Douglas wrote:
> We had tracked this down and fixed it once already. It's back:
> Creating PBuffer Using GLX 1.3
> X Error of failed request: GLXUnsupportedPrivateRequest
> Major opcode of failed request: 143 (GLX)
> Minor opcode of failed request: 16 (X_GLXVendorPrivate)
> Serial number of failed request: 21
> Current serial number in output stream: 22
> This happens specifically when trying to export high resolution PPM from
> nviz.
> http://grass.itc.it/pipermail/grass5/2006-June/023868.html
If they don't work, you can turn them off:
export GRASS_NO_GLX_PBUFFERS=1
export GRASS_NO_GLX_PIXMAPS=1
I'm starting to get really curious as to whether either pBuffers or
GLX Pixmaps actually work for *anyone*.
