[GRASS-dev] GL + PPM + nviz
Hamish
hamish_nospam at yahoo.com
Fri Sep 8 05:36:33 EDT 2006
> > Brad Douglas wrote:
> >> We had tracked this down and fixed it once already. It's back:
> >> Creating PBuffer Using GLX 1.3
> >> X Error of failed request: GLXUnsupportedPrivateRequest
> >> Major opcode of failed request: 143 (GLX)
> >> Minor opcode of failed request: 16 (X_GLXVendorPrivate)
> >> Serial number of failed request: 21
> >> Current serial number in output stream: 22
> >> This happens specifically when trying to export high resolution PPM
> >from > nviz.
Markus, Brad, does this work for you in 6.1.0?
In 6.3 if you do:
> If they don't work, you can turn them off:
> export GRASS_NO_GLX_PBUFFERS=1
> export GRASS_NO_GLX_PIXMAPS=1
As the problem appears to be widespread, I propose to disable off-
screen rendering for the 6.2 release branch and work on fixing the
problem in 6.3-cvs.
Hamish
