[GRASS-dev] GL + PPM + nviz
Markus Neteler neteler at itc.it
Fri Sep 8 09:25:02 EDT 2006
Hamish wrote on 09/08/2006 11:36 AM:
>>> Brad Douglas wrote:
>>>> We had tracked this down and fixed it once already.  It's back:
>>>> Creating PBuffer Using GLX 1.3
>>>> X Error of failed request:  GLXUnsupportedPrivateRequest
>>>>   Major opcode of failed request:  143 (GLX)
>>>>   Minor opcode of failed request:  16 (X_GLXVendorPrivate)
>>>>   Serial number of failed request:  21
>>>>   Current serial number in output stream:  22
>>>> This happens specifically when trying to export high resolution PPM
>> >from > nviz.
> Markus, Brad,   does this work for you in 6.1.0?
NVIZ volume + NVIZ highres output fail in 6.1.0.
I would need a version before May 2006 to see if it was broken
by the togl update and related changes.
Does anyone have a CVS snapshot from April?
Markus
