[GRASS-dev] GL + PPM + nviz
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Sep 8 10:19:11 EDT 2006
I have a February 2006 CVS on my Mac, but I need to finish my talk
first, then I can test,
hopefully later today or tomorrow, unless somebody else responds too.
Helena
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Sep 8, 2006, at 9:25 AM, Markus Neteler wrote:
> Hamish wrote on 09/08/2006 11:36 AM:
>>>> Brad Douglas wrote:
>>>>> We had tracked this down and fixed it once already.  It's back:
>>>>> Creating PBuffer Using GLX 1.3
>>>>> X Error of failed request:  GLXUnsupportedPrivateRequest
>>>>>   Major opcode of failed request:  143 (GLX)
>>>>>   Minor opcode of failed request:  16 (X_GLXVendorPrivate)
>>>>>   Serial number of failed request:  21
>>>>>   Current serial number in output stream:  22
>>>>> This happens specifically when trying to export high resolution
>>>>> PPM
>>>> from > nviz.
>> Markus, Brad,   does this work for you in 6.1.0?
> NVIZ volume + NVIZ highres output fail in 6.1.0.
> I would need a version before May 2006 to see if it was broken
> by the togl update and related changes.
> Does anyone have a CVS snapshot from April?
> Markus
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
