[GRASS-dev] problems with thematic mapper (was "added opacity
option to grc file")
Michael Barton
michael.barton at asu.edu
Mon Sep 11 12:53:17 EDT 2006
I don't know what's going on, but I just tried to create a thematic map and
got the following error:
csh: if: Expression Syntax.
d.vect.thematic: awk required, please install awk or gawk first
I DO have awk installed (I double checked). I made no changes to the
d.vect.thematic script that should cause this error.
Does anyone have an idea what's going on?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Mon, 11 Sep 2006 17:14:44 +0200
> To: Michael Barton <michael.barton at asu.edu>
> Subject: Re: added opacity option to grc file
> Michael Barton wrote:
>> Moritz,
>> This will be nice if it doesn't break anything.
>> The optlist is used for a variety of things and was designed for options for
>> a d.* command. Opacity is not one of those options. It is a value used for
>> compositing when g.pnmcomp is run.
>> I should look to see where optlist is being used again besides in creating a
>> list of options for *.grc output. But I'm assuming that it would be obvious
>> if this caused a problem.
> Let's hope. Sorry, I should have consulted you before committing.
> I have another problem which is also new: it seems as if the thematic
> layer only displays the highest (last) class. Below you see the messages
> in the output window. Nothing seems to be going wrong, but in the
> display I only see those areas which are in the range 4152.66 - 20174.
> Moritz
> ******output**************
> Thematic map legend for column densite of map communes
> Value range: 0 - 20174
> Mapped by standard deviation units of 1747.52 (mean = 657.62)
> Color(R:G:B) Value
> 0:0:255 0 - 657.62
> PNG: GRASS_TRUECOLOR status: TRUE
> PNG: collecting to file:
> /home/mlennert/GRASS/DATA/BELGIQUE/mlennert/.tmp/geog-pc40/32172.0.ppm,
> GRASS_WIDTH=642, GRASS_HEIGHT=482
> 'vector/communes' was found in more mapsets (also found in mlennert).
> 85:0:170 657.62 - 2405.14 +1sd
> 170:0:85 2405.14 - 4152.66 +2sd
> 255:0:0 4152.66 - 20174
>> Michael
>> Center for Social Dynamics & Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Mon, 11 Sep 2006 12:13:09 +0200
>>> Subject: added opacity option to grc file
>>> Hello Michael,
>>> Just to inform you: I just added support for the opacity option in the
>>> .grc file to cvs:
>>> http://grass.itc.it/pipermail/grass-commit/2006-September/024186.html
>>> Moritz
