[GRASS-dev] d.vect.thematic problem
Michael Barton
michael.barton at asu.edu
Mon Sep 11 16:41:23 EDT 2006
Earlier today, I reported that d.vect.thematic is not running on my Mac,
returning the error
csh: if: Expression Syntax.
d.vect.thematic: awk required, please install awk or gawk first
The code in d.vect.thematic that is causing this is the following...
#### check if we have awk
if [ ! -x "`which awk`" ] ; then
echo "$PROG: awk required, please install awk or gawk first" 2>&1
exit 1
fi
If I run...
>>which awk
...from the a plain vanilla bash Terminal.app window, it returns ...
/usr/bin/awk
But if I run it from the GRASS Terminal.app window, it returns...
This is with William Kyngesburye¹s binaries of 2 Sept. 2006. Any idea what¹s
wrong?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060911/fec18674/attachment.html
