[GRASS-dev] [bug #5129] (grass) ps.map: vpoints with sizecol not sorted to put larger behind smaller icons
Request Tracker grass-bugs at intevation.de
Tue Sep 12 05:34:54 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5129
Subject: ps.map: vpoints with sizecol not sorted to put larger behind smaller icons
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060912
When creating sizeable point symbols with the vpoints command and the sizecol option, ps.map does not sort the icons so that larger are behind smaller ones. This can make smaller ones invisible sometimes.
Moritz
-------------------------------------------- Managed by Request Tracker
