[GRASS-dev] [bug #5130] (grass) d.vect.chart: objects sized with sizecol not sorted to put larger behind smaller icons
Request Tracker grass-bugs at intevation.de
Tue Sep 12 05:36:25 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5130
Subject: d.vect.chart: objects sized with sizecol not sorted to put larger behind smaller icons
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060912
When creating sizeable point symbols with d.vect.chart it does not sort the icons so that larger are behind smaller ones. This can make smaller ones invisible sometimes.
Moritz
-------------------------------------------- Managed by Request Tracker
