[GRASS-dev] v.what and spatial index
Moritz Lennert
mlennert at club.worldonline.be
Wed Sep 13 09:32:00 EDT 2006
Glynn Clements wrote:
> Moritz Lennert wrote:
>>>> How would this change from the first approach (if v.what could easily be
>>>> made to accept multiple coordinates) ? This would again mean 'blindly'
>>>> collecting points before seeing the results, or having to call v.what
>>>> multiple times.
>>> v.what would read one coordinate pair, perform the lookup, write out
>>> the result(s), repeat until EOF.
>>> gis.m would start one v.what process; each time you click the mouse
>>> button, it would send the coordinates to the v.what process, read the
>>> result, then display it. It would need to restart v.what if the set of
>>> maps changed, but could use a single process to look up multiple
>>> points.
>> Here's my attempt at applying what you suggest. It's not very
>> complicated, and seems to work fine here, but I'd appreciate if someone
>> could check that I didn't do anything wrong before committing.
> One issue which won't show up when running it directly from the shell,
> but will if you run it via pipes: you need to explicitly set stdin and
> stdout to line-buffered operation with e.g.:
> setvbuf(stdin, NULL, _IOLBF, 0);
> setvbuf(stdout, NULL, _IOLBF, 0);
I assume this can be done anywhere as long as its before the call to stdin ?
>> Now we will have to change the query function in the gis manager (from
>> line 1474 of gui/tcltk/gis.m/mapcanvas.tcl) to use v.what with the -s
>> flag and to provide continuous flow of coordinates and an EOF at the
>> end. Michael, can you do this ? Or could someone tell me in rough lines
>> how this can be done ?
> Ah. Tcl's "open" function doesn't directly support using pipes for
> both stdin and stdout; you can choose read (stdout is a pipe, stdin is
> inherited) or write (stdin is a pipe, stdout is inherited), but not
> both.
> You will need to create a named pipe (with mkfifo) then explicitly
> redirect one of the ends to it, e.g.
> set fifo $tmpdir/$tmpname
> exec mkfifo $fifo
> set rfh [open "|v.what map=$maplist <$fifo" r]
> fconfigure $rfh -buffering line
> set wfh [open $fifo w]
> fconfigure $wfh -buffering line
Ok, I understand the principle of this, but don't know how and where to
apply it in mapcanvas.tcl. Don't have the time to dig into it right now.
Michael ?
Another question is whether it is worth doing all this (don't know how
much work it is to apply Glynn's solution) if we are going to change GUI
in a foreseeable future...
Thanks, Glynn, for your help.
Moritz
