[GRASS-dev] v.what and spatial index
Trevor Wiens
twiens at interbaun.com
Wed Sep 13 09:50:24 EDT 2006
On Wed, 13 Sep 2006 15:32:00 +0200
Moritz Lennert wrote:
> >>>> How would this change from the first approach (if v.what could easily be
> >>>> made to accept multiple coordinates) ? This would again mean 'blindly'
> >>>> collecting points before seeing the results, or having to call v.what
> >>>> multiple times.
> >>> v.what would read one coordinate pair, perform the lookup, write out
> >>> the result(s), repeat until EOF.
> >>> gis.m would start one v.what process; each time you click the mouse
> >>> button, it would send the coordinates to the v.what process, read the
> >>> result, then display it. It would need to restart v.what if the set of
> >>> maps changed, but could use a single process to look up multiple
> >>> points.
> >> Here's my attempt at applying what you suggest. It's not very
> >> complicated, and seems to work fine here, but I'd appreciate if someone
> >> could check that I didn't do anything wrong before committing.
> > One issue which won't show up when running it directly from the shell,
> > but will if you run it via pipes: you need to explicitly set stdin and
> > stdout to line-buffered operation with e.g.:
> > setvbuf(stdin, NULL, _IOLBF, 0);
> > setvbuf(stdout, NULL, _IOLBF, 0);
> I assume this can be done anywhere as long as its before the call to stdin ?
> >> Now we will have to change the query function in the gis manager (from
> >> line 1474 of gui/tcltk/gis.m/mapcanvas.tcl) to use v.what with the -s
> >> flag and to provide continuous flow of coordinates and an EOF at the
> >> end. Michael, can you do this ? Or could someone tell me in rough lines
> >> how this can be done ?
> > Ah. Tcl's "open" function doesn't directly support using pipes for
> > both stdin and stdout; you can choose read (stdout is a pipe, stdin is
> > inherited) or write (stdin is a pipe, stdout is inherited), but not
> > both.
> > You will need to create a named pipe (with mkfifo) then explicitly
> > redirect one of the ends to it, e.g.
> > set fifo $tmpdir/$tmpname
> > exec mkfifo $fifo
> > set rfh [open "|v.what map=$maplist <$fifo" r]
> > fconfigure $rfh -buffering line
> > set wfh [open $fifo w]
> > fconfigure $wfh -buffering line
> Ok, I understand the principle of this, but don't know how and where to
> apply it in mapcanvas.tcl. Don't have the time to dig into it right now.
> Michael ?
> Another question is whether it is worth doing all this (don't know how
> much work it is to apply Glynn's solution) if we are going to change GUI
> in a foreseeable future...
Moritz,
Thanks for doing this. This change will also be useful for future GUI's.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
