[GRASS-dev] v.what and spatial index
Thu Sep 14 02:40:02 EDT 2006
Moritz Lennert wrote:
> > One issue which won't show up when running it directly from the shell,
> > but will if you run it via pipes: you need to explicitly set stdin and
> > stdout to line-buffered operation with e.g.:
> > 	setvbuf(stdin,  NULL, _IOLBF, 0);
> > 	setvbuf(stdout, NULL, _IOLBF, 0);
> I assume this can be done anywhere as long as its before the call to stdin ?
It needs to be done before anything reads from stdin or writes to
stdout.
