[GRASS-dev] Overlay grids and lines tool in gism fails to dra
wgrid in map wi ndow
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 15 09:00:57 EDT 2006
Patton, Eric wrote:
> Ok. But d.grid worked for me in late July using the default color settings
> in gis.m (some kind of light grey), without having to first use a predefined
> color. The manpage says that RGB triplets can be used. Is this no longer the
> case then?
I see:
revision 2.5
date: 2006/04/18 05:19:49; author: cedric; state: Exp; lines: +6 -38
Added gisprompts for color. Uses simplified (abstracted) color handling.
Removed colors.h header.
See diff here:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/display/d.grid/main.c.diff?r1=2.4&r2=2.5
This might be the problem, although it happened in April...
Moritz
