[GRASS-dev] GRASS: wrong directory settings in g.manual
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 15 09:42:05 EDT 2006
This is probably a specific debian problem, but sending it to the
grass-dev list as well, just in case.
g.manual fails on debian since the directory settings are wrong.
In g.manual there is
GRASS_DOC_BASE="$GISBASE"
and html and man pages are looked for under:
$GRASS_DOC_BASE"/docs/html/$1.html
and
$GRASS_DOC_BASE"/man/man1/$1.1
However, in debian/grass-doc.install there are the following lines,
installing the docs into more LFS-compliant (I assume) directories:
usr/lib/grass/docs/html usr/share/doc/grass-doc
usr/lib/grass/man/man1 usr/share/man
Thus g.manual fails.
So, should this be changed directly in the GRASS tree, or is this a
debian patch issue ?
Moritz
