[GRASS-dev] GRASS: wrong directory settings in g.manual
Glynn Clements
glynn at gclements.plus.com
Sat Sep 16 09:12:28 EDT 2006
Moritz Lennert wrote:
> This is probably a specific debian problem, but sending it to the
> grass-dev list as well, just in case.
> g.manual fails on debian since the directory settings are wrong.
> In g.manual there is
> GRASS_DOC_BASE="$GISBASE"
> and html and man pages are looked for under:
> $GRASS_DOC_BASE"/docs/html/$1.html
> and
> $GRASS_DOC_BASE"/man/man1/$1.1
> However, in debian/grass-doc.install there are the following lines,
> installing the docs into more LFS-compliant (I assume) directories:
> usr/lib/grass/docs/html usr/share/doc/grass-doc
> usr/lib/grass/man/man1 usr/share/man
> Thus g.manual fails.
> So, should this be changed directly in the GRASS tree, or is this a
> debian patch issue ?
Only the Debian patch should be changed.
