[Fwd: Re: [GRASS-dev] GL + PPM + nviz]
Brad Douglas
rez at touchofmadness.com
Fri Sep 15 18:27:49 EDT 2006
Listers,
The OpenGL portion of the nviz high-resolution PPM export does not work
as intended for most individuals at present:
-------- Forwarded Message --------
To: rez at touchofmadness.com
Cc: Markus Neteler <neteler at itc.it>
Subject: Re: [GRASS-dev] GL + PPM + nviz
Date: Fri, 15 Sep 2006 18:38:07 +0100
Brad Douglas wrote:
> > For the foreseeable future, the only viable approach is to allow the
> > user to explicitly enable or disable such features.
> Then I guess the best that can be done is to ensure that
> GRASS_NO_GLX_PIXMAPS and GRASS_NO_GLX_PBUFFERS are widely documented.
> Would it be best to set them for now until conditions improve to
> minimize user impact?
I suggest putting that question to the mailing list(s).
If they are disabled by default, the variable names should probably
have the "NO_" removed, and accept 0/1 values, e.g.
GRASS_GLX_PIXMAPS=0 # force off
GRASS_GLX_PIXMAPS=1 # force on
# anything else = default = off for now, on if the feature eventually
# becomes usable on the majority of systems
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
