[GRASS-dev] Re: MS-Windows native GRASS
Michael Barton
michael.barton at asu.edu
Mon Sep 18 10:27:19 EDT 2006
Thanks for this clarification. Now I have a couple more specific questions.
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Mon, 18 Sep 2006 11:32:12 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Huidae Cho <grass4u at gmail.com>
> Subject: Re: MS-Windows native GRASS
> Michael Barton wrote:
>> Can you give an example of how you need to run a bash script under windows?
> If $cmd is a script, you need to explicitly specify the interpreter.
> E.g.:
> exec $cmd $arg1 $arg2
> needs to be changed to:
> exec sh $cmd $arg1 $arg2 # for a shell script
> or:
This should go into the runandoutput.tcl procedures. Can this be used for
all systems, or do I need to specify that this syntax is for mysys platforms
only? env(HOSTTYPE)=???
> exec $env(GRASS_WISH) $cmd $arg1 $arg2 # for a Tcl/Tk script
> etc.
Running a tcltk script from within tcltk shouldn't need this should it
(i.e., from within a WISH environment)? Calling wish should only be
necessary when starting a tcltk script from the command line or its
equivalent in mysys, right? This would be in the gis.m script.
> Note that:
> exec sh -c "$cmd $arg1 $arg2"
> will work in some cases, but not all, so shouldn't be used.
>> Sorry, but I don't quite get it yet. You suggest that this same syntax also
>> runs under unix. Under Linux? Mac? I'm happy to test it on the Mac and at
>> least a flavor or two of Linux.
> It's unnecessary under Unix (including OSX); you can just execve() a
> script, and the kernel will detect the #!/bin/sh and invoke /bin/sh
> automatically.
> This isn't the case on Windows. Unix emulation layers (e.g. Cygwin,
> MinGW's bash) include specific code to detect scripts and invoke the
> interpreter.
So it's an issue with mysys only? Does it hurt to specify sh up front for
ALL, or do we need to do this only for mysys platforms?
Thanks
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
