[GRASS-dev] creating new modules
Kirk R. Wythers kwythers at umn.edu
Wed Sep 20 11:58:18 EDT 2006
Maxi,
Thanks for contribution to the wiki. I am very interested in your
work with HydroFOSS. Since you likely have confronted already, many
of the issues that I am struggling with, I would like to ask you a
few questiions.
First off, how do you organize your meteorological data in time and
space? For example, over a landscape there will be numerous
observations for variables such as precipitation, temperature and
solar radiation. The more I think about it, the more sophisticated
the database requirements for this task seem to be.
Right now, I am leaning toward setting up vector layers (and
associated postgresql tables) for variables such as vegetation type
and soil type. For example, the model will need to know soil type at
any given location and needs to access precipitation data through
time in oder to calculate water availability. In turn, water
availability through time will then be needed for photosynthesis
calculations which will have further temporally dependent input
requirements such as solar radiation, and temperature.
Keeping these data (both input and output) organized and accessible,
through the model run seems to be my most challenging task at this
point.
Any thoughts are much appreciated,
Kirk
On Sep 20, 2006, at 5:55 AM, Massimiliano Cannata wrote:
> HI, I've just added some notes on the Wiki page....
> for people interested in ETP, please take a look at http://
> w3.ist.supsi.ch:8001/geomatica/
> hope it could be set up a working team on environmental modelling ;-)
> Maxi
>>> Kirk R. Wythers, Research Fellow
>>> Dept. of Forest Resources
>>> University of Minnesota
>>> 1530 Cleveland Ave N
>>> Saint Paul, MN 55108
>>> tel: 612.625.2261
>>> email: kwythers at umn.edu
>> Scott W. Mitchell    Scott_Mitchell at carleton.ca
>> Geomatics and Landscape Ecology Research Laboratory
>> Department of Geography and Environmental Studies
>> Carleton University, B349 Loeb Building
>> Ottawa, ON Canada K1S 5B6
>> +1-613-520-2600 ext 2695
> Dr. Eng. Massimiliano Cannata
> Responsabile Area Geomatica
> Istituto Scienze della Terra
> Scuola Universitaria Professionale della Svizzera Italiana
> Via Trevano, c.p. 72
> CH-6952 Canobbio-Lugano
> Tel: +41 (0)58 666 62 14
> Fax +41 (0)58 666 62 09
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060920/3bbd4257/attachment.html
