[GRASS-dev] creating new modules
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Wed Sep 27 05:00:10 EDT 2006
Sorry for my delay.
Inline some comments.
Kirk R. Wythers wrote:
> Maxi,
> Thanks for contribution to the wiki. I am very interested in your work
> with HydroFOSS. Since you likely have confronted already, many of the
> issues that I am struggling with, I would like to ask you a few
> questiions.
> First off, how do you organize your meteorological data in time and
> space? For example, over a landscape there will be numerous
> observations for variables such as precipitation, temperature and
> solar radiation. The more I think about it, the more sophisticated the
> database requirements for this task seem to be.
Basically I used two external DB table: one for stations (with east,
north, id) and one for values (with id, timestamp, value,
parameter_type), then i run a query and import the result as vector with
v.in.ascii
This is a dirty solution, and some discussion on series in grass are
going on also for this propouse.
> Right now, I am leaning toward setting up vector layers (and
> associated postgresql tables) for variables such as vegetation type
> and soil type. For example, the model will need to know soil type at
> any given location and needs to access precipitation data through time
> in oder to calculate water availability. In turn, water availability
> through time will then be needed for photosynthesis calculations which
> will have further temporally dependent input requirements such as
> solar radiation, and temperature.
> Keeping these data (both input and output) organized and accessible,
> through the model run seems to be my most challenging task at this point.
For HydroFOSS running I just used a name convention for series handling:
[series_name].[series_time]
in this way i loop trough time ($time_now & $time_last) and used the
correct input in command running, e.g.:
r.mapcal 'landuse.$time_now=landuse.$time_last + 10'
> Any thoughts are much appreciated,
> Kirk
> On Sep 20, 2006, at 5:55 AM, Massimiliano Cannata wrote:
>> HI, I've just added some notes on the Wiki page....
>> for people interested in ETP, please take a look at
>> http://w3.ist.supsi.ch:8001/geomatica/
>> hope it could be set up a working team on environmental modelling ;-)
>> Maxi
>>>> Kirk R. Wythers, Research Fellow
>>>> Dept. of Forest Resources
>>>> University of Minnesota
>>>> 1530 Cleveland Ave N
>>>> Saint Paul, MN 55108
>>>> tel: 612.625.2261
>>>> email: kwythers at umn.edu <mailto:kwythers at umn.edu>
>>> Scott W. Mitchell Scott_Mitchell at carleton.ca
>>> <mailto:Scott_Mitchell at carleton.ca>
>>> Geomatics and Landscape Ecology Research Laboratory
>>> Department of Geography and Environmental Studies
>>> Carleton University, B349 Loeb Building
>>> Ottawa, ON Canada K1S 5B6
>>> +1-613-520-2600 ext 2695
>> Dr. Eng. Massimiliano Cannata
>> Responsabile Area Geomatica
>> Istituto Scienze della Terra
>> Scuola Universitaria Professionale della Svizzera Italiana
>> Via Trevano, c.p. 72
>> CH-6952 Canobbio-Lugano
>> Tel: +41 (0)58 666 62 14
>> Fax +41 (0)58 666 62 09
