[GRASS-dev] autoconf, LOC_CHECK_VERSION_INT
Markus Neteler neteler at itc.it
Wed Sep 20 15:48:33 EDT 2006
On Wed, Sep 20, 2006 at 07:03:44PM +0200, Radim Blazek wrote:
> Hi.
> I cannot create configure with autoconf 2.59, error:
> configure.in:362: warning: AC_CANONICAL_HOST invoked multiple times
> autoconf/specific.m4:363: AC_CYGWIN is expanded from...
> configure.in:362: the top level
> configure.in:44: error: possibly undefined macro: AC_MSG_ERROR
>      If this token and others are legitimate, please use m4_pattern_allow.
>      See the Autoconf documentation.
hi Radim,
so far I always used autoconf-2.13 (which still works).
Could you try that version as well? Or do you eed to
use 2.59?
Markus
> The reason I need to create configure is that macro
> LOC_CHECK_VERSION_INT fails on crosscompiler,
> patch is attached.
> Radim
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
