[GRASS-dev] autoconf, LOC_CHECK_VERSION_INT
Radim Blazek
radim.blazek at gmail.com
Fri Sep 22 07:42:59 EDT 2006
On 9/20/06, Markus Neteler <neteler at itc.it> wrote:
> On Wed, Sep 20, 2006 at 07:03:44PM +0200, Radim Blazek wrote:
> > Hi.
> > I cannot create configure with autoconf 2.59, error:
> > configure.in:362: warning: AC_CANONICAL_HOST invoked multiple times
> > autoconf/specific.m4:363: AC_CYGWIN is expanded from...
> > configure.in:362: the top level
> > configure.in:44: error: possibly undefined macro: AC_MSG_ERROR
> > If this token and others are legitimate, please use m4_pattern_allow.
> > See the Autoconf documentation.
> hi Radim,
> so far I always used autoconf-2.13 (which still works).
> Could you try that version as well? Or do you eed to
> use 2.59?
Yes, I forgot that it must be 2.13.
Radim
> Markus
> > The reason I need to create configure is that macro
> > LOC_CHECK_VERSION_INT fails on crosscompiler,
> > patch is attached.
> > Radim
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
