[GRASS-dev] v.to.db type=area: bug or typo?
Maciej Sieczka
tutey at o2.pl
Thu Sep 21 06:31:21 EDT 2006
Radim,
While updating the v.to.db manual I noticed that 'type=area' is
mentioned twice in the 'Examples':
v.to.db map=soils type=area option=cat
v.to.db map=soils type=area option=area col=area_size unit=h
But v.to.db says:
Error: value <area> out of range for parameter <type>
Legal range: point,line,boundary,centroid
It was reported on Feb 2006 http://intevation.de/rt/webrt?serial_num=4044.
Shall I update the description (replace 'type=area' with
'type=centroid' ???) or is it a bug in v.to.db?
Maciek
