[GRASS-dev] EXE_SUFFIX
Glynn Clements
glynn at gclements.plus.com
Thu Sep 21 12:53:58 EDT 2006
Radim Blazek wrote:
> Can you tell me why EXE_SUFFIX was removed from Platform.make while
> it was left in Module.make and other places?
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/Make/Platform.make.in.diff?r1=1.54&r2=1.55
> Consequently executables on windows don't have .exe extension.
> Can you please enable .exe extensions again?
I changed the variable to $(EXE), as that tends to be more common (and
easier to read); EXE is set from EXEEXT, which is set by the AC_EXEEXT
autoconf macro.
I'll update Module.make accordingly.
