[GRASS-dev] EXE_SUFFIX
Radim Blazek radim.blazek at gmail.com
Fri Sep 22 06:58:15 EDT 2006
On 9/21/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
> > Can you tell me why EXE_SUFFIX was removed from Platform.make while
> > it was left in Module.make and other places?
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/Make/Platform.make.in.diff?r1=1.54&r2=1.55
> > Consequently executables on windows don't have .exe extension.
> > Can you please enable .exe extensions again?
> I changed the variable to $(EXE), as that tends to be more common (and
> easier to read); EXE is set from EXEEXT, which is set by the AC_EXEEXT
> autoconf macro.
> I'll update Module.make accordingly.
EXE_SUFFIX is also used in other Makefile files where default
Module.make cannot be used, 53 files in total.
Radim
