[GRASS-dev] adding 'desc' to dbf sql driver
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 22 05:09:34 EDT 2006
Reworking on d.vect.chart I need to be able to sort the reults of a
select in descending order. As the dbf driver doesn't allow this, I have
been trying to see how to extend the driver.
IIUC, it's "just" a question of conditionalising the qsort call on line
566 of db/drivers/dbf/dbfexe.c, and (would this be enough ?) use
qsort(set, nset, sizeof(int), -cmp_row);
if the desc keyword is present.
However, I have some trouble understanding the parsing of the sql
statement.
If I understand correctly, we would need to extent the SQLPSTMT
structure in include/sqlp.h to include a flag for 'desc' (and possible
'asc') and the parser to identify and set that flag.
But this is as far as I get. Could someone help me with this ?
Thanks,
Moritz
