[GRASS-dev] v.kernel, v.neighbors output type
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Sep 22 08:12:54 EDT 2006
On Fri, 22 Sep 2006, Radim Blazek wrote:
> On 9/22/06, Markus Neteler <neteler at itc.it> wrote:
>> Hi Radim,
>> I guess that it would be easiest to reenable your CVS commit
>> for such things - it should be sufficient to send the new
>> public ssh key to Bernhard Reiter <bernhard at intevation.de>.
> Yes,
> ssh key is not problem, it is still the same, the problem is IP.
> I think that the protection which requires IP is exagerated for GRASS.
> SF does not use this kind of protection and it does not seem to have
> problems.
FWIW my CVS access isn't restricted by IP address because there were some
problems we couldn't sort it out when setting it up, and Bernhard removed
the restriction.
Paul
