[GRASS-dev] v.kernel, v.neighbors output type
Radim Blazek
radim.blazek at gmail.com
Fri Sep 22 08:07:48 EDT 2006
On 9/22/06, Markus Neteler <neteler at itc.it> wrote:
> Hi Radim,
> I guess that it would be easiest to reenable your CVS commit
> for such things - it should be sufficient to send the new
> public ssh key to Bernhard Reiter <bernhard at intevation.de>.
Yes,
ssh key is not problem, it is still the same, the problem is IP.
I think that the protection which requires IP is exagerated for GRASS.
SF does not use this kind of protection and it does not seem to have
problems.
Radim
> If this doesn't work for you, I could take care of this change.
> ciao
> Markus
> On Fri, Sep 22, 2006 at 01:42:01PM +0200, Radim Blazek wrote:
> > Hi,
> > v.kernel and v.neighbors have output option defined as TYPE_STRING
> > thus GUI cannot identify that option as output.
> > It should use G_define_standard_option(G_OPT_R_OUTPUT) instead.
> > Thanks
> > Radim
