[GRASS-dev] [bug #5167] (grass) v.patch: -a(ppend) issues
Request Tracker grass-bugs at intevation.de
Sat Sep 23 08:43:56 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5167
Subject: v.patch: -a(ppend) issues
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006-09-23
$ v.patch -e -a input=map1 output=map2
Error: option <output>: <map2> exists.
Should v.patch in -a(ppend) mode automatically set the --ovewrite flag?
It kind-off works:
$ v.patch -e -a input=map1 output=map2 --o
But leaves the output vector in a somewhat strange state - it is OK for Grass commands (v.digit, v.info -c) but QGIS (current SVN head) complains about it that "No layers available in this map". After I v.build this vector, QGIS accepts it.
v.build helps, but it shouldn't be required. v.patch should output a valid vector. Or maybe this is QGIS fault?
What do you think Radim?
Maciek
-------------------------------------------- Managed by Request Tracker
