[GRASS-dev] interferring ovewrite flags [was: [bug #5167] (grass)
v.patch: -a(ppend) issues]
Maciej Sieczka
tutey at o2.pl
Sun Sep 24 08:08:09 EDT 2006
A followup:
There are 2 more Grass commands that provide an overwrite flag that
intereferes with --o:
r.lake:
-o Overwrite seed map with result (lake) map
r.mask
-o Overwrite existing MASK
That should be fixed. As weel as the v.patch case.
In case of this one the use of -o is propably bogus - non of the
remaining Grass export modules provide an ovewrite flag:
r.out.gridatb
-o Overwrite output map file
The last one, but I'm not sure if the --o flag will interfere, haven't
checked:
v.db.connect
-o Overwrite connection parameter for certain layer
Maciek
