[GRASS-dev] interferring ovewrite flags [was: [bug #5167]
(grass) v.patch: -a(ppend) issues]
Michael Barton
michael.barton at asu.edu
Sun Sep 24 18:20:25 EDT 2006
R.mask is a shell script, so the -o flag is there to run the underlying
GRASS module with --o.
Is there a better way to do this script programmers?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciej Sieczka <tutey at o2.pl>
> Date: Sun, 24 Sep 2006 14:08:09 +0200
> Cc: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] interferring ovewrite flags [was: [bug #5167] (grass)
> A followup:
> There are 2 more Grass commands that provide an overwrite flag that
> intereferes with --o:
> r.lake:
> -o Overwrite seed map with result (lake) map
> r.mask
> -o Overwrite existing MASK
> That should be fixed. As weel as the v.patch case.
> In case of this one the use of -o is propably bogus - non of the
> remaining Grass export modules provide an ovewrite flag:
> r.out.gridatb
> -o Overwrite output map file
> The last one, but I'm not sure if the --o flag will interfere, haven't
> checked:
> v.db.connect
> -o Overwrite connection parameter for certain layer
> Maciek
