[GRASS-dev] interferring ovewrite flags [was: [bug #5167] (grass)
v.patch: -a(ppend) issues]
Maciej Sieczka
tutey at o2.pl
Mon Sep 25 05:53:57 EDT 2006
Michael Barton wrote:
> R.mask is a shell script, so the -o flag is there to run the underlying
> GRASS module with --o.
> Is there a better way to do this script programmers?
r.reclass (used in r.mask) supports --o as all other Grass raster
modules do (besides r.mapcalc).
I checked r.mask and it doesn't matter whether you use it with -o or
--o. In both cases the output is ovewritten, so you just remove your -o.
Looks like parser takes care of it.
Maciek
