[GRASS-dev] GRASS digitizing;
splitting lines does not update the cat!
Stephan Holl
holl at gdf-hannover.de
Mon Sep 25 11:06:54 EDT 2006
Hi devs,
while working with a very long digitized coastline I encountered the
following problem.
I split the line into pieces in order to give different attributes to
different line segments.
But when I split the line, the cat stays identical. So whenever I
change an attribute of one segment, it gets changed on all other
segments too (because it has the same cat).
This is because no new attribute-entry will be created when a line is
split and the cat stays identical.
Would this be a big deal to change this? Where is the right place to
look at?
My needed behaviour would be that when splitting a line, the
attribute-entry gets copied, the new resulting segment gets a new cat
linked to the copied entry. The left-of-new-point-segment stays old, the
right-of-new-point-segment gets the new cat linked to the new cat.
What do other think? Is this a convnient usecase?
Could this be done with GRASS/QGIS right now?
Thanks for your comments.
Best regards
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
