[GRASS-dev] Updated docs for v.to.points (please add to CVS)
Patton, Eric epatton at nrcan.gc.ca
Wed Sep 27 06:28:18 EDT 2006
I've expanded on the v.to.points manpage, specifically addressing the
effects of selecting different options for the 'type' parameter as requested
in BT#2802 (patch attached). Can someone verify and add any corrections
necessary? If it's ok, please add to cvs.
Maciek, I think this final edit to v.to.points should close BT#2802 for good
- all outstanding requests in that ticket have been satisfied.
Thanks,
~ Eric.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060927/f753e45d/v.to.points.description.html.obj
