[GRASS-dev] GRASS6.2.0beta3 startup error
Wed Sep 27 06:56:11 EDT 2006
William L. Baker wrote:
> Hello,
> Just starting again with GRASS, so this could be dumb error on my part.
> 6.2.0beta3 compiles OK (although I did not check any error logs), but
> upon entering a location and mapset I get the following error. I'm on
> SuSe 10.1.
> Bill Baker, Univ. of Wyomg
> _________________________________________________________
> Welcome to GRASS 6.2.0beta3 (2006)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the graphical user interface with: gis.m &
> When ready to quit enter:                exit
> GRASS 6.2.0beta3 (rmnp):/home/bakerwl > Error in startup script: can't
> read "monitor_zooms(1,1,n)": no such variable
>     while executing
> "lappend region $monitor_zooms($mon,1,$attr)"
>     (procedure "MapCanvas::currentzoom" line 13)
>     invoked from within
> "MapCanvas::currentzoom $mon"
>     (procedure "MapCanvas::coordconv" line 23)
>     invoked from within
> "MapCanvas::coordconv $mon"
>     (procedure "MapCanvas::create" line 68)
>     invoked from within
> "MapCanvas::create"
>     (procedure "Gm::startmon" line 11)
>     invoked from within
> "Gm::startmon"
>     (procedure "Gm::create" line 69)
>     invoked from within
> "Gm::create"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/local/grass-6.2.0beta3/etc/gm/gm.tcl" line 522)
do you still see this with 6.2.0RC1 ?
Hamish
