[GRASS-dev] [bug #5161] v.digit: no toolbox if Grass 6.3 built with tcl/tk 8.3
Michael Barton michael.barton at asu.edu
Fri Sep 29 10:50:42 EDT 2006
Hamish,
Bwidget LabelFrame (note capitalization) might work as a substitute. There
has to be some kind of bwidget sourcing to make it work. If it's just one
function call, it would be easy. But from past reports, it's not just one
call in nviz, but includes other things as well.
For me at least, it quite a bit of work to try and track down what has
changed since 8.4 was released 3.5 years ago and find some workaround for
each one. I'm not trying to be a pain, I just don't have time to do that,
fix current bugs, fulfill new wishes, and work on the new wxPython interface
too. I'm pretty much the only person doing this, and so have to draw the
line somewhere since I'm already overcommitted. And like the rest of the
developers, I do have a day job too that keeps me pretty busy. Sorry.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Fri, 29 Sep 2006 22:33:59 +1200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>, <grass-bugs at lists.intevation.de>
> Subject: Re: [GRASS-dev] [bug #5161] v.digit: no toolbox if Grass 6.3 built
> with tcl/tk 8.3
> Michael Barton wrote:
>> I believe that other things will break if you try to run gism with
>> TclTk 8.3. I know that the georectifier uses a labelframe, and I'm
>> pretty sure that there are other items scattered here and there. Like
>> I noted before, 8.4 has been out for many years, is widely available,
>> and is near to being replaced by 8.5. So I only have lukewarm concern
>> for things that don't run in 8.3. Life is too short and the GRASS team
>> salaries aren't all that great ;-). If you want to track them down and
>> find an old way to achieve this, I guess that's OK. But I'm not sure
>> it's worth it.
> For the sake of 1 lousy function call in v.digit, we should figure out a
> way to keep GRASS compatible with TclTk 8.3. If a solution doesn't avail
> itself soon I will revert the latest v.digit changes in the 6.2 branch
> to make it so, even though I think your updates are really nice.
> I didn't get an answer: will sourcing lib/external/bwidget/labelframe.tcl
> solve the problem?
> WRT gis.m, that's your baby & I'm not going to tell you what to do with
> it (there's still d.m), but I will point out that many people are still
> using 8.3 (as seen from recent bug reports) and we should go to some
> active length to stay compatible with it. Not just when convenient, but
> at some reasonable trouble.
> There's some mantra which goes something like "just because it doesn't
> affect me, doesn't mean it won't cause a world of trouble for someone
> else."  see also C99 vs. ANSI C vs. POSIX discussions.
> best,
> Hamish
> ps - actually, it doesn't look bad at all:
> grass63$ grep -riI labelframe * | cut -f1 -d: | sort | uniq
> lib/external/bwidget/CHANGES.txt
> lib/external/bwidget/CVS/Entries
> lib/external/bwidget/README
> lib/external/bwidget/combobox.tcl
> lib/external/bwidget/font.tcl
> lib/external/bwidget/labelentry.tcl
> lib/external/bwidget/pkgIndex.tcl
> lib/external/bwidget/spinbox.tcl
> lib/gtcltk/options.tcl
> vector/v.digit/toolbox.tcl
> visualization/nviz/src/tkInt8.4.9.h
> visualization/nviz/src/tkInt8.4.h
> bwidget stuff is all 4 years old and lib/gtcltk/options.tcl is a false
> postive.
