[GRASS-dev] Re: [GRASS-user] Solaris 10
Glynn Clements
glynn at gclements.plus.com
Fri Sep 29 13:55:29 EDT 2006
[CC'd to developers.]
Bencze Sándor wrote:
> Other problems when trying to open Spearfish:
> GRASS 6.1.0 (spearfish60):~ > Error in startup script: unknown option "-elide"
> while executing
> "$textarea tag configure e1 -elide 1"
> (procedure "Gronsole::create_command" line 50)
I would guess that this is a Tcl/Tk compatibility issue.
> I have a brand new 8.5 Tcl/Tk installed on the machine. Are there compatibility problems?
I suspect that you've just found one. I don't know of any developers
who are using Tcl/Tk 8.5.
For now, you'll need to use "grass61 -text".
