[GRASS-dev] discussion: replacing ps.map
Glynn Clements
glynn at gclements.plus.com
Mon Apr 2 03:34:49 EDT 2007
Glynn Clements wrote:
> The original unscaled raster function R_RGB_raster() is only used by
> i.point, i.vpoints and i.class. They could be changed to use the
> scaled raster functions with 1:1 scaling, although I'm not sure that I
> understand them well enough to test any changes, and I'm not sure if
> it's worth the effort (AFAIK, they should all be obsolete soon).
I've changed them to use the scaled raster functions (D_draw_d_raster
rather than D_d_raster). i.points seems to work okay (although I'm not
all that familiar with it), and the other two have almost identical
code. Even so, I'd appreciate it if someone could test these changes.
