[GRASS-dev] discussion: replacing ps.map
Mon Apr 2 07:21:24 EDT 2007
Glynn Clements wrote:
> > The original unscaled raster function R_RGB_raster() is only used by
> > i.point, i.vpoints and i.class. They could be changed to use the
> > scaled raster functions with 1:1 scaling, although I'm not sure that I
> > understand them well enough to test any changes, and I'm not sure if
> > it's worth the effort (AFAIK, they should all be obsolete soon).
> I've changed them to use the scaled raster functions (D_draw_d_raster
> rather than D_d_raster). i.points seems to work okay (although I'm not
> all that familiar with it), and the other two have almost identical
> code. Even so, I'd appreciate it if someone could test these changes.
Also changed: photo.2target and photo.2image.
