[GRASS-dev] possible etc file finder function
William Kyngesburye kyngchaos at kyngchaos.com
Mon Apr 2 23:32:46 EDT 2007
On Apr 2, 2007, at 9:37 PM, Glynn Clements wrote:
> I don't think that what you are trying do is practical. Add-on modules
> should just go into $GISBASE.
As I suggested in a previous message to the list, putting addon
modules in GISBASE is actually the impractical part.
http://grass.itc.it/pipermail/grass-dev/2007-March/029975.html
Especiallly on OSX, *adding* to an already installed application
(.app package) is not recommended.  And a non-admin user will simply
not be able to do that.
> However, if you want to make a module look elsewhere for its data
> files, use an environment variable rather than a compile-time setting.
Fully controlling by the env var is probably a good idea, so it's
like PATH and [DY]LD_LIBRARY_PATH. hmmm.  I'd have to figure out how
to split strings in C to reduce it to one env var that works like the
other env vars.
Any comments on the C itself?  I wasn't sure about memory allocation
stuff, I'm not good with that.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
