[GRASS-dev] possible etc file finder function
Glynn Clements
glynn at gclements.plus.com
Mon Apr 2 22:37:16 EDT 2007
William Kyngesburye wrote:
> Per my note about accessing user addon modules outside the GRASS
> application installation, such as in their home folder, I made an
> attempt at a function to locate a file in configured etc locations.
> I'm not much of a C programmer, and really I just modified a copy of
> find_file.c. Tear it apart and give it to me straight ^_^
> The 3 possible etc folder locations it will look are:
> 1: the user's home folder
> 2: a globa/system folder
> 3: the GRASS application folder (or, the current default)
> It needs a couple configured vars to set the user and global
> folders. I put these in in a new etc.h. The user dir is relative to
> HOME and the global should be an absolute dir. ie, for OSX:
> #define ETC_PATH_USER "Library/GRASS/6.3/Modules/etc"
> #define ETC_PATH_GLOBAL "/Library/GRASS/6.3/Modules/etc"
> Existing, builtin, modules don't need to be changed to use this.
> It's really only necessary for external modules that have support
> data files. v.in.dwg would be an example, if that was built and
> installed outside the GRASS application (and that is probably
> necessary for binary distributions).
I don't think that what you are trying do is practical. Add-on modules
should just go into $GISBASE.
However, if you want to make a module look elsewhere for its data
files, use an environment variable rather than a compile-time setting.
