[GRASS-dev] possible etc file finder function
William Kyngesburye
woklist at kyngchaos.com
Mon Apr 2 16:30:12 EDT 2007
Per my note about accessing user addon modules outside the GRASS
application installation, such as in their home folder, I made an
attempt at a function to locate a file in configured etc locations.
I'm not much of a C programmer, and really I just modified a copy of
find_file.c. Tear it apart and give it to me straight ^_^
The 3 possible etc folder locations it will look are:
1: the user's home folder
2: a globa/system folder
3: the GRASS application folder (or, the current default)
It needs a couple configured vars to set the user and global
folders. I put these in in a new etc.h. The user dir is relative to
HOME and the global should be an absolute dir. ie, for OSX:
#define ETC_PATH_USER "Library/GRASS/6.3/Modules/etc"
#define ETC_PATH_GLOBAL "/Library/GRASS/6.3/Modules/etc"
Existing, builtin, modules don't need to be changed to use this.
It's really only necessary for external modules that have support
data files. v.in.dwg would be an example, if that was built and
installed outside the GRASS application (and that is probably
necessary for binary distributions).
Skipped content of type multipart/appledouble-------------- next part --------------
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike. Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings. And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
