[GRASS-dev] Re: discussion: replacing ps.map
Jachym Cepicky jachym.cepicky at gmail.com
Tue Apr 3 06:01:14 EDT 2007
2007/4/3, Glynn Clements <glynn at gclements.plus.com>:
> Jachym Cepicky wrote:
> > for having general picture, here [1] is PDF [11MB] with map symbols
> > used in czech forestry (NOTE: symbol pictures are starting on page
> > 31).
> > It would be great to be able to create such maps in GRASS. Currently,
> > I think that the biggest problem is line styling. Maybe it would be
> > interesting to follow the polygon way: If lines could be drawn using
> > some eps pattern, this would be solved.
> > Jachym
> > [1] http://les-ejk.cz/tmp/czech-forest-maps.pdf
> I get a 404 "Not Found" error for that URL.
sorry, I did not noticed, that the upload failed - I posted it here:
http://wwwold.fle.czu.cz/~jachym/tmp/czech-forest-maps.pdf
> While you can fill areas (including stroked paths) with arbitrary
> patterns, those patterns won't be oriented to follow the path. If you
> want complex line styles, you generally have to do most of the work
> yourself.
"Myself" means to edit the resulting Post Script file(?).
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
