[GRASS-dev] [grass-code I][353] g.mlist through gis.m in GRASS6.2
and 6.3
Glynn Clements
glynn at gclements.plus.com
Tue Apr 3 06:59:14 EDT 2007
grass-codei at wald.intevation.org wrote:
> In the g.mlist panel (File -> Manage maps and volumes -> List maps
> using expressions and 'wildcards') is written "map name search
> pattern, must be 'quoted'. (default:all):"
> Actually the option works only if the string is not quoted.
IOW: option descriptions should not assume that the module is being
run from a shell.
Fixed in CVS.
