[GRASS-dev] [grass-code I][356] Georectifier auto-extension
grass-codei at wald.intevation.org
Tue Apr 3 16:22:52 EDT 2007
code I item #356, was opened at 2007-04-03 22:22
Status: Open
Priority: 3
Submitted By: Francesco Lovergine (frankie)
Assigned to: Nobody (None)
Summary: Georectifier auto-extension
Issue type: module bad feature
Issue status: None
GRASS version: 6.2.1
GRASS component: gis.m
Operating system: Linux
Operating system version: Debian sid
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Georectifier calls i.rectify with a pid extension. This is quite bad. For instance, when rectifying an hyperspectral image with bands numbered 1..200, you will get many rasters with long random suffixes such as:
myimage.4812345
which is ugly. It would be much more sane asking the user an extension (e.g. I prefer a 'R' suffix for manually rectified images).
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=356&group_id=21
