[GRASS-dev] errors in: messages
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Apr 4 04:12:50 EDT 2007
hello,
I get various "errors in:" messages after an update. So far I did not find
similar threats on the mailing lists.
After a cvs update, make distclean - configure - make, a long list of "errors
in:" is prompted (see below).
I deleted my old cvs folder and removed the grass files in /usr/local and did
a fresh cvs but still the same error appears.
It is a temporal problem or did I forget something?
Using debian testing.
TIA Martin
Errors in:
...//grass/grass6/lib/proj
...//grass/grass6/lib/vector/Vlib
...//grass/grass6/lib/sites
...//grass/grass6/lib/rst/interp_float
...//grass/grass6/lib/ogsf
...//grass/grass6/db/drivers/ogr
...//grass/grass6/display/d.extend
...//grass/grass6/display/d.extract
...//grass/grass6/display/d.grid
...//grass/grass6/display/d.path
...//grass/grass6/display/d.vect
...//grass/grass6/display/d.vect.chart
...//grass/grass6/display/d.what.vect
...//grass/grass6/display/d.where
...//grass/grass6/display/d.zoom
...//grass/grass6/general/g.proj
...//grass/grass6/general/g.region/cmd
...//grass/grass6/general/g.setproj
...//grass/grass6/general/manage/cmd
...//grass/grass6/general/manage/lister
...//grass/grass6/imagery/i.vpoints
...//grass/grass6/ps/ps.map
...//grass/grass6/raster/r.carve
...//grass/grass6/raster/r.contour
...//grass/grass6/raster/r.cost
...//grass/grass6/raster/r.drain
...//grass/grass6/raster/r.flow
...//grass/grass6/raster/r.le/r.le.setup
...//grass/grass6/raster/r.out.gdal
...//grass/grass6/raster/r.proj
...//grass/grass6/raster/r.proj.seg
...//grass/grass6/raster/r.random
...//grass/grass6/raster/r.region
...//grass/grass6/raster/r.resamp.rst
...//grass/grass6/raster/r.sun
...//grass/grass6/raster/r.sunmask
...//grass/grass6/raster/r.to.vect
...//grass/grass6/raster/r.volume
...//grass/grass6/raster/r.walk
...//grass/grass6/raster/simwe/simlib
...//grass/grass6/raster/simwe/r.sim.water
...//grass/grass6/raster/simwe/r.sim.sediment
...//grass/grass6/raster/r.in.gdal
...//grass/grass6/vector/v.buffer
...//grass/grass6/vector/v.build
...//grass/grass6/vector/v.build.polylines
...//grass/grass6/vector/v.category
...//grass/grass6/vector/v.clean
...//grass/grass6/vector/v.convert
...//grass/grass6/vector/v.db.connect
...//grass/grass6/vector/v.db.select
...//grass/grass6/vector/v.distance
...//grass/grass6/vector/v.drape
...//grass/grass6/vector/v.edit
...//grass/grass6/vector/v.extract
...//grass/grass6/vector/v.extrude
...//grass/grass6/vector/v.hull
...//grass/grass6/vector/v.info
...//grass/grass6/vector/v.in.ascii
...//grass/grass6/vector/v.in.db
...//grass/grass6/vector/v.in.dxf
...//grass/grass6/vector/v.in.region
...//grass/grass6/vector/v.in.sites
...//grass/grass6/vector/v.kcv
...//grass/grass6/vector/v.kernel
...//grass/grass6/vector/v.label
...//grass/grass6/vector/v.lrs/lib
...//grass/grass6/vector/v.lrs/v.lrs.create
...//grass/grass6/vector/v.lrs/v.lrs.segment
...//grass/grass6/vector/v.lrs/v.lrs.label
...//grass/grass6/vector/v.lrs/v.lrs.where
...//grass/grass6/vector/v.proj
...//grass/grass6/vector/v.mkgrid
...//grass/grass6/vector/v.neighbors
...//grass/grass6/vector/v.net
...//grass/grass6/vector/v.net.alloc
...//grass/grass6/vector/v.net.iso
...//grass/grass6/vector/v.net.path
...//grass/grass6/vector/v.net.salesman
...//grass/grass6/vector/v.net.steiner
...//grass/grass6/vector/v.normal
...//grass/grass6/vector/v.out.ascii
...//grass/grass6/vector/v.out.dxf
...//grass/grass6/vector/v.out.pov
...//grass/grass6/vector/v.out.svg
...//grass/grass6/vector/v.out.vtk
...//grass/grass6/vector/v.overlay
...//grass/grass6/vector/v.parallel
...//grass/grass6/vector/v.patch
...//grass/grass6/vector/v.perturb
...//grass/grass6/vector/v.split
...//grass/grass6/vector/v.qcount
...//grass/grass6/vector/v.random
...//grass/grass6/vector/v.reclass
...//grass/grass6/vector/v.sample
...//grass/grass6/vector/v.segment
...//grass/grass6/vector/v.select
...//grass/grass6/vector/v.support
...//grass/grass6/vector/v.surf.idw
...//grass/grass6/vector/v.surf.rst
...//grass/grass6/vector/v.transform
...//grass/grass6/vector/v.to.db
...//grass/grass6/vector/v.to.points
...//grass/grass6/vector/v.to.rast
...//grass/grass6/vector/v.to.rast3
...//grass/grass6/vector/v.type
...//grass/grass6/vector/v.univar
...//grass/grass6/vector/v.voronoi
...//grass/grass6/vector/v.what
...//grass/grass6/vector/v.what.rast
...//grass/grass6/vector/v.vol.rst
...//grass/grass6/vector/lidar/lidarlib
...//grass/grass6/vector/lidar/v.surf.bspline
...//grass/grass6/vector/lidar/v.outlier
...//grass/grass6/vector/lidar/v.lidar.correction
...//grass/grass6/vector/lidar/v.lidar.edgedetection
...//grass/grass6/vector/lidar/v.lidar.growing
...//grass/grass6/vector/v.out.ogr
...//grass/grass6/vector/v.in.ogr
...//grass/grass6/vector/v.external
...//grass/grass6/vector/v.digit
...//grass/grass6/visualization/nviz
Finished compilation: Tue Apr 3 18:48:46 CEST 2007
(In case of errors please change into the directory with error and run 'make')
make: *** [default] Error 1
