[GRASS-dev] errors in: messages
Hamish
hamish_nospam at yahoo.com
Wed Apr 4 04:33:14 EDT 2007
Martin Wegmann wrote:
> I get various "errors in:" messages after an update. So far I did not
> find similar threats on the mailing lists.
> After a cvs update, make distclean - configure - make, a long list of
> "errors in:" is prompted (see below).
> I deleted my old cvs folder and removed the grass files in /usr/local
> and did a fresh cvs but still the same error appears.
> It is a temporal problem or did I forget something?
> Using debian testing.
> TIA Martin
> Errors in:
> ...//grass/grass6/lib/proj
--snip--
> (In case of errors please change into the directory with error and run
> 'make')
please do that, starting with lib/proj
note nothing has changed in lib/proj in a month.
is ".../" real or a search & replace?
Hamish
