[GRASS-dev] errors in: messages
Glynn Clements
glynn at gclements.plus.com
Wed Apr 4 06:08:08 EDT 2007
Martin Wegmann wrote:
> > > I get various "errors in:" messages after an update. So far I did not
> > > find similar threats on the mailing lists.
> > > After a cvs update, make distclean - configure - make, a long list of
> > > "errors in:" is prompted (see below).
> > > I deleted my old cvs folder and removed the grass files in /usr/local
> > > and did a fresh cvs but still the same error appears.
> > > It is a temporal problem or did I forget something?
> > > Using debian testing.
> > > TIA Martin
> > > Errors in:
> > > ...//grass/grass6/lib/proj
> > --snip--
> > > (In case of errors please change into the directory with error and run
> > > 'make')
> > please do that, starting with lib/proj
> baliola at wpf063:~/software/grass/grass6$ cd lib/proj/
> baliola at wpf063:~/software/grass/grass6/lib/proj$ make
> gcc -shared -o /home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gproj.6.3.cvs.so -L/home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib
> OBJ.i686-pc-linux-gnu/get_proj.o OBJ.i686-pc-linux-gnu/do_proj.o
> OBJ.i686-pc-linux-gnu/convert.o OBJ.i686-pc-linux-gnu/datum.o
> OBJ.i686-pc-linux-gnu/ellipse.o -lgrass_gis -lgrass_datetime -lz -lproj -L/usr/local/lib -lgdal -lodbc -lodbcinst -ljasper -lmfhdf -ldf -lgif -ljpeg -ltiff -lpng -lnetcdf -lcfitsio -L/usr/local/grass-6.3.cvs//lib -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_I -lgrass_gproj -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime -lpq -L/usr/lib -lpq -lz -lm -lrt -ldl
> (cd /home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib;
> ln -f -s
> libgrass_gproj.6.3.cvs.so /home/baliola/software/grass/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so)
> /usr/bin/ld: cannot find -lgrass_vect
As libgrass_gproj library doesn't use libgrass_vect, this is almost
certainly a GDAL issue (i.e. your GDAL library was built with GRASS
support, but you've removed the GRASS installation on which it
depends). If that is the case, you will first need to re-install GDAL;
if you're building it from source, you'll need to build without GRASS
support.
