[GRASS-dev] FW: [grass-code I][355] A lot of <defunct> processes
around while working - Georectifier
Michael Barton
michael.barton at asu.edu
Wed Apr 4 17:12:55 EDT 2007
I just looked at georect.tcl
All 'open' calls to g.region are to return values and are followed by
closes. So I'm not sure where this is from.
Using the georectifier does also use the map display. So maybe it is due to
the issue I just fixed by switching open to exec for calling g.region in the
set_wind procedure.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
------ Forwarded Message
> From: <grass-codei at wald.intevation.org>
> Reply-To: <grass-codei at wald.intevation.org>
> Date: Wed, 4 Apr 2007 22:23:00 +0200 (CEST)
> To: <noreply at wald.intevation.org>
> Subject: [grass-code I][355] A lot of <defunct> processes around while working
> code I item #355, was opened at 2007-04-03 22:15
> Status: Open
> Priority: 3
> Submitted By: Francesco Lovergine (frankie)
>> Assigned to: Michael Barton (michael)
> Summary: A lot of <defunct> processes around while working
> Issue type: module bug
> Issue status: None
> GRASS version: 6.2.1
> GRASS component: gis.m
> Operating system: Linux
> Operating system version: Debian sid
> GRASS CVS checkout date, if applies (YYMMDD):
> Initial Comment:
> While using georectifier a lot of pending defuncts appear for g.region. It
> seems (?) parent does not loop on wait() while managing SIGCHLD process as it
> should. All processes are closed when gm.tcl is terminated.
> frankie 5484 1 2 16:49 pts/11 00:00:32 wish
> /usr/lib/grass/etc/gm/gm.tcl -name gm_tcl
> frankie 5525 5484 0 16:49 pts/11 00:00:00 [g.region] <defunct>
> frankie 5527 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5529 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5590 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5602 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5605 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5608 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5616 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5623 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5654 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5683 5484 0 16:50 pts/11 00:00:00 [g.region] <defunct>
> frankie 5706 5484 0 16:51 pts/11 00:00:00 [g.region] <defunct>
> frankie 5718 5484 0 16:51 pts/11 00:00:00 [g.region] <defunct>
> frankie 5729 5484 0 16:51 pts/11 00:00:00 [g.region] <defunct>
> frankie 5739 5484 0 16:52 pts/11 00:00:00 [g.region] <defunct>
> frankie 5751 5484 0 16:52 pts/11 00:00:00 [g.region] <defunct>
> frankie 5763 5484 0 16:52 pts/11 00:00:00 [g.region] <defunct>
> frankie 5774 5484 0 16:53 pts/11 00:00:00 [g.region] <defunct>
> frankie 5784 5484 0 16:53 pts/11 00:00:00 [g.region] <defunct>
> frankie 5794 5484 0 16:53 pts/11 00:00:00 [g.region] <defunct>
> frankie 5805 5484 0 16:54 pts/11 00:00:00 [g.region] <defunct>
> frankie 5821 5484 0 16:54 pts/11 00:00:00 [g.region] <defunct>
> frankie 5922 5484 0 16:55 pts/11 00:00:00 [g.region] <defunct>
> frankie 5932 5484 0 16:56 pts/11 00:00:00 [g.region] <defunct>
> frankie 5943 5484 0 16:56 pts/11 00:00:00 [g.region] <defunct>
> frankie 5955 5484 0 16:57 pts/11 00:00:00 [g.region] <defunct>
> frankie 5965 5484 0 16:57 pts/11 00:00:00 [g.region] <defunct>
> frankie 6030 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> frankie 6054 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> frankie 6086 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> frankie 6096 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> frankie 6128 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> frankie 6160 5484 0 16:58 pts/11 00:00:00 [g.region] <defunct>
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=355&group_id=21
------ End of Forwarded Message
