[GRASS-dev] FW: [grass-code I][355] A lot of <defunct> processes around while working - Georectifier
Thu Apr 5 08:42:28 EDT 2007
Michael Barton wrote:
> I just looked at georect.tcl
> All 'open' calls to g.region are to return values and are followed by
> closes. So I'm not sure where this is from.
> Using the georectifier does also use the map display. So maybe it is due to
> the issue I just fixed by switching open to exec for calling g.region in the
> set_wind procedure.
I'm fairly sure that's the case. I searched for "g.region" in the
gis.m code, and the one in MapCanvas::set_wind is the only one which
looked wrong.
